First Land Cruiser 2025 or 2026 ??
I have a 25 Hybrid and it is a decent vehicle. Only issue is the constant brake SQUEAL when using brakes in reverse. Toyota aware but has no fix and no idea when they will fix. Had I known this I would not have bought the vehicle!
If that squealing pad is bothering you enough to regret the vehicle altogether, you can replace the brake pad for less than a hundred bucks and solve the issue.
Welcome to the asylum.
Hello all - torn between ordering a 2025 or 26 4Runner TRD pro vs the LC premium 2026 - switching my good old 5th gen 4R (off road) .. wondering if there are any insights on 2026 changes or updates for the LC ?
The 3 things that Iโ€™m indecisive on are :
1- internal storage vs limited storage on the LC
2- all time 4wd vs the part time on the 4runner
3- clearance vs limited clearance on the LC for deep snow
Point 1- nothing I can do about :( unless Toyota listens to the community and do some changes!! Which is highly unlikely as that will include redesign of the interior !
Point 2- I would like to hear the owners opinions - or recommendations especially for Canadian winters and snowy Weather conditions - mostly on road use - my old 4R did well for years in many snow storms but wondering if the full time 4wd would make any difference vs better ground clearance with part time 4wd when needed ? Definitely the slightly bigger fuel tank on the TRD pro takes the extra point vs. The LC :)
For point 3 - I appreciate if anyone can guide me if I can gain ~ 1โ€ lift with just replacing tires/wheels without a lift -i.e on factory suspension with no trimming or having the tires extend beyond the fenders ? If so any recommendations on tires/wheel sizes/details?
The ground clearance difference between my 5th gen 4R at 9.6โ€ and new LC at 8.7โ€ is 0.9โ€ compared to an extra 0.5โ€ lift with the new TRD pro at 10.1โ€ clearance .., Iโ€™m good with the 9.6โ€ clearance worked well for me in many snow storms :) - any feedback back would be appreciated helps me get closer to a decision โ€ฆ
Thank you.
Hello all - torn between ordering a TRD pro vs the LC premium 2026 - switching my good old 5th gen 4R (off road) .. wondering if there are any insights on 2026 changes or updates for the LC ?
Thank you.
Sorry, what are you comparing the LC to? You say TRD PRO but not which model.
Thank you.
2. All time 4WD vs the part time on the 4Runner.
If your fifth gen 4Runner worked just fine in Canadian winters, Iโ€™m not sure what you would gain from a Land Cruiser. There is a YouTube channel called โ€˜Engineering Explainedโ€™, and the guy goes over the Torsen differential and how it works. You be the judge..
3. Clearance vs limited clearance on the LC for deep snow.
Iโ€™m not sure why you are sweating ground clearance for a vehicle that will be used mainly โ€˜on roadโ€™, but there are forty eleven threads on tires, and lift kits on this forum. You just have to search and read.
Love the 4wd system which I feel is superior. Used in deep snow many times! If your worried about ground clearance it can plow the road for you.
Thank you.
  1. I'm coming from an FJ, the Land Cruiser has more storage. I don't find it very limiting.
  2. Many years back, between Toyota Trucks, I had a Subaru and rented a couple full time 4WD Jeeps. I'll never own a vehicle that isn't AWD/full time 4WD again if I can help it. Much more for on road safety in poor conditions (like snow) than off-road. The Land Cruiser having full time 4WD was what made me decide to sell my 11 year old FJ Cruiser with full time 4WD (only the manual transmission FJ had that) and kept me from replacing it with a 4Runner before that.
  3. It's only an inch or two difference between the Land Cruiser and the 4Runner, not that much?
2026 Land Cruiser -- it will be a few months before we know much, but personally I'd be really surprised if there are major differences from the 2025. The 2024 was a very short model year, I wouldn't expect Toyota to make any significant revisions until the 2027 or 2028 model year. They did give the GX a 1" lift in the second model year, but only a special off-road version -- I wouldn't expect Toyota to do anything like that with the Land Cruiser unless it was part of a special off-road package or trim. @ricochet did a review of the lifted GX and noted that the on road feel is slightly worse, they wouldn't want to force everyone into that tradeoff.
Thanks for the reply-
Yes Iโ€™m leaning more for the LC for the all time 4wd and center diff..
Regarding Clearance - Iโ€™m not concerned during normal drives or highways Iโ€™m more concerned when away from home on isolated roads - where snow can get deep pretty quick in a storm ;)
But I guess I can still lift the LC but canโ€™t get the all time 4wd on the 4R TRD pro
So thanks - more points towards the LC now ..
Thanks for the reply - not sure Iโ€™ll wait till 26 or 27 :) .. I did test drive the 2025 LC - very stable and way less nose dives than my 5th Gen 4Runner -
Iโ€™m leaning now more towards the LC - interior is nicer - Iโ€™ll be looking at slightly bigger tires :)
Thanks
What most people do NOT mention, is that if you put a lift kit on your rig, whether itโ€™s a Tacoma, FourRunner, or Land Cruiser, that portion of your Toyota warranty, goes out the window.
Hmmโ€ฆ do you know if that also applies to just going with bigger /different size tires/ wheels than whatโ€™s originally fitted?
I do not know. I read elsewhere about Toyota not honoring their warranty when a lift was done. I think it was about bearings going bad on the front end of Tacomaโ€™s, where Toyota would not cover the repair under warranty. The upside, there are better bearings available that negate the damage of the new increased angles of lifted Tacomas.
It varies by jurisdiction. Iโ€™m unsure about Canada, but in the United States they need to demonstrate that the non-OEM parts caused the issue to the OEM parts. You could see if your jurisdiction has legislation similar to the Magnuson-Moss Warranty Act in the USA.
Thatโ€™s insightful - Iโ€™ll most probably get the tires/wheels from the dealership and hold them accountable to ensure everything remains under warranty :)
Saw some LCs with TRD pro wheels they look great on black LC
IMO your warranty would be honored with any tire size that was offered by the dealership, even if you didn't buy them from the dealer. There should be no issue with the wheels.
If you put on a lift kit, that's a whole new ball of wax. It would be easy for Toyota to not warranty a whole slew of components due to increased forces etc........ (like mentioned above, not sure about Canada's laws)
Agree. Iโ€™ve already had some fairly significant warranty work on parts very adjacent to the wheels (CV, drive axle) and they didnโ€™t bat an eye on the oversized and very heavy tires I have on aftermarket wheels. In my experience Toyota really stands behind their product.
