Dash Cam
spend the time snaking the rear camera cable through the hatch, install the rear camera on the glass, cleaner and away from being knocked off.
there are several post in YT, some took the easy way installing the rear camera
FitcamX has old and crappy 5mp IMX335 sensor.
Go with a true 4K IMX678 sensor:
You would be able to recognize the license plate numbers
FitcamX has an old and crappy 5mp IMX335 sensor.
We recently started carrying the Mangoal cameras as well due to the STARVIS sensor and true 4K recording. I just ordered a few and will do a comparison here shortly between the two. From my extensive conversations with my Mangoal rep before listing these, I am optimistic these will outperform the FitCamX (which I've always really liked) by a good margin.
We have Amazon's price beat as well!
I'm thinking of running this exact setup, the X310 in the front and mini 3 in the rear with the Garmin OBD constant power adapter. Im worried about the battery consumption in parking mode since from what I understand the cutoff is 12.0V. I was planning to set the switch on the adapter to 24h and on the garmin dashcam itself to something like 8h.
What settings do you currently run and what settings that you ran in the past gave you issues?
Thanks a lot for any input!
I just checked.
The Gamin OBD adapter is set at the lowest possible setting… 10 min.
I also checked the capacitor type battery jump booster that I bought one year ago at Costco, on our trip to the redwoods, and it was STILL charged to 100%. So I may worry less if I reach down and blindly slide the switch over one notch to 24hours when traveling, and staying at motels.
Reactions: amw
I just checked.
Thank you!
