Not a big deal to install the switch, but not trivial either. There is a procedure on this site that takes you thru the process of removing the back liftgate interior panel. This wiring is fairly straight forward, so long as you don't try to install an "auto off" timer, like I did -- there were some interactions between the car's control unit and the timer, that led to voltage outputs that I did not understand -- so rather than fuss with it I just abandoned the timer and just installed a simple on/off switch.
And now for some bitching....... Not only is it totally absurd that Toyota installed the lights without a switch, AND they did it without setting them up to automatically turn off after 20 minutes like the other cargo lights, but they did this in conjunction with a tiny 12-volt battery (AND TOYOTA UNDERSTANDS THE SMALL 12V BATTERY PROBLEM in electrified cars, just as them about how the Yaris has been doing...)
This whole battery issue on this car is, in my opinion, a big deal. If I had known this ahead of time, I probably would have waited a year and bought a non-hybrid 4Runner instead... It's not out of the question that I may still do so, but there are a ton of things that I DO like about the LC, and I've already put a lot of time & money into the LC trying to bring it up to a "minimum competence level" (stuff like skid plates, BFG K03 tires, a new battery, a battery monitor, pig-tails for both a wall charger and a solar charger, cargo cover, etc.)
