Another dead battery
Are you using the Toyota App? While it doesn't update mileage and other functions in real time (seems to be on it's own schedule sometimes), that is probably how Big Brother at least in the form of the Toyota Mothership knows mileage and service due dates.
Edit- the Toyota privacy policy you go through when you initially set up the Land Cruiser while taking delivery is likely the culprit with Carfax, and potentially insurance companies. My sales person suggested "opting out" and I do see there is a setting to do so in the Toyota App in the account tab.
No I don't use the app, opted out in the dealer's parking lot when I took delivery, which is why I think it's always reporting without my consent. I also opted out on my Tacoma and I don't receive any unwanted correspondence from anyone concerning anything on it.
It would be nice if I could just pay for the vehicle, have access to everything that came on the vehicle without signing up or paying for anything, unless I expressly signed up for something extra. As an example ...... carplay is installed at delivery and I can use car play "as is" without signing up for anything!
Interesting. When you say the dealer and Carfax know your mileage, were their numbers accurate or projected based on your average to date?
Asking out of curiosity. I do use the app myself but opted out of additional information sharing.
they are withing 100 miles of what's on the odo. I've attempted to opt out of CarFax........... we'll see.
I called Toyota roadside service both times the battery in mine died. I'd recommend doing that and mentioning it in the appointment details if your dealer is being cheap about a $90 battery replacement.
After two no-starts in 3800KM of driving and a fresh battery from Toyota, I removed the Toyota app from my phone. The amount of notifications I get when that car is parked - it's the only thing I could think of that could drain the 12V battery on a daily driven vehicle.
Your theory has merit, however my brand new 2020 Tacoma's battery went bad 3-4 months after I took possession. So in regards to the LC adjusting the battery down to "X" voltage doesn't make sense to me because if that were the case why, isn't the hybrid system maintaining "X" voltage in the dormant state.......... IMO it's the DCM system constantly reporting the vehicles location/status back to whoever is storing that information. Otherwise why am I getting notices from my servicing dealer and Carfax telling me my LC has "X" miles and I'll need an oil change soon and would I like to schedule one..........
EOD - I’m with you. The more I look - the more questions.
Questions -
- Are these Yuasa 12v batteries from Japan poor quality?
They don’t appear to be robust enough for the LC charging profile.
- Is there a parasitic drain - like possibly from connected services working overtime to connect in poor reception areas?
My BS200 isn’t showing a steady parasitic drain. We need more data.
- Why do both lead-acid & AGM 12v batteries settle to the same voltage, lower than a conventional charging systems?
THe LC wants the 12v battery supply @ 12.3v-12.5v. Don’t know why.
- Is Toyota intentionally targeting a low resting voltage with the battery-current sensor and DC-DC control strategy?
Possibly, it’s doing it to both lead & AGM batteries.
- When does the LC charge the 12v battery supply- @ startup, certain mileage, voltage threshold, some many hours?
I need to get home & test running voltage.
Anyone know the answers?
Sideshow -
Heck I even found a 3rd battery on-board - 86725-06020 ($312) is a small lithium battery used to back up mobile & connected services. It’s located in the center console under where the phone charger is located. Don’t think it’s part of our concerns, but interesting that connected services can stay alive when 12v battery goes off line…
ideshow -
Safety feature to allow the SOS function to operate independently from whether it can get power from the DC to DC convertor or 12V system in the event of an emergency.
Appears to be a standard 18650 Li-Ion battery wrapped in a protective jacket, those can be quite dangerous and readily start fires when both ends touch the same metal!
