WHO KNOWS THE MANUFACTURER OF THE LC FE ROOF RACK?
I do know for a fact that ARB fittings work well, I have several different flavors of ARB Base Rack accessories. Cross members also have an M8 or 5/16 t-slot down the center (slot is just under 11 mm wide)
This place has tons of stuff. You could
Always look here and shop
Elsewhere but the rings I bought were fair deal.
They ship out of Canada so they took some time to get to Arizona but I do like them and high quality product
I bought these
Those look nice, but I worry about the small load bearing area of the bolt and am likely overthinking it... I actually started using SS Unistrut spring nut plates - you just rip the spring off and they fit down the slot. After that, you buy the eye/hook/FHCS/BHCS/etc you want. They're among the cheapest solutions I could identify and still stainless steel
First set of anything like this I have purchased but you make a good point. I did use them on our last trip and worked out well but will still be looking for options. I like that they slide into the slot on my Wescott rack that does not have the drill outs for the slots.
That's a huge point. Even on the OEM rack with access to the slot at either end, when you use nut-plates you still have to plan it out before or disassemble after!!
