Two engine coolant fill locations?
Hiker42
๐Ÿ“› Founding Member
Aug 21, 2024
90
85
Atlanta, GA
Grand Cherokee
I noticed my Land Cruiser has what appears to be two separate engine coolant filler locations. Are these for two separate coolant circuits?
The small tank up by the firewall on the passenger side is for the hybrid cooling system. The one at the front is normal ICE radiator fill tank.
Anyone else front coolant level (pink) near the L level. It's been like that since factory and hasn't changed much so I'm not worried. I was just curious if maybe it was underfilled from factory?
When cold or hot?
Just checked mine, it is at full mark when cold.
From the factory - both coolant reservoirs were at the L mark when cold on mine. Iโ€™ll eventually add a bit more in each reservoir.
Also the oil was overfilled past the top mark about 1/4 inch.
