Yes provided the extra space for pins are there, which typically Toyota won't use different connectors between trims, they sometimes however leave wiring, pins or both out though.So theoretically, we could just wire into these connectors?
I might not be correct as I have an FE, and have no knowledge on the 1958, but I believe the pass-though harness, corresponding door harness and the mirror harness are tailored to the options for the specific vehicle....... ie ....... curtesy mirror lights, mirror cameras and heated glass. While the connectors may have empty slots where the wires/pins for the options are supposed to go, the wires aren't physically there.So theoretically, we could just wire into these connectors?
I’m contemplating buying the LC grade door trim (comes with door harness) for my 1958, and I’m curious whether the extra interior lights will function. They’re not primary motivator, so would just try it and see.I might not be correct as I have an FE, and have no knowledge on the 1958, but I believe the pass-though harness, corresponding door harness and the mirror harness are tailored to the options for the specific vehicle....... ie ....... curtesy mirror lights, mirror cameras and heated glass. While the connectors may have empty slots where the wires/pins for the options are supposed to go, the wires aren't physically there.
Does the 1958 have the door proximity lights? If so It should work. The issue as I see it is the Cabin side of the wiring. Then it'll be the modules to make everything work OEM style etc......... Not insurmountable but expensive, unless you can find a wrecked one in a "U-pull-it" yard and strip the wires and modules etc......I’m contemplating buying the LC grade door trim (comes with door harness) for my 1958, and I’m curious whether the extra interior lights will function. They’re not primary motivator, so would just try it and see.
