Side body moldings
I just installed my moldings... I think they look great! And a bit of a bonus -- they seem to all but eliminate the tinny hollow sound that the doors had (due to lack of sound insulation)...
Good observation. I've been wondering why my doors sound better when closing. Thought I was just getting used to the tinny sound. But you might be right, I could see the moldings stiffening up the sheet metal and improving the hollow sound.
Wind Chill Pearl, easy install. Two different lightings in the pictures. They do add another element of look.
I paid about $280.00 plus tax, from a local Toyota Dealer parts department. I read somewhere that if a dealer installs they, they can charge close to $300.00 to install them (not sure if that is accurate)., but, if you take your time, measure 2-3 time to make sure the measurements are correct, you will do great.
Paid $480 dealer installed, total parts and labor.
Hello,
I ended buying the moldings for my LC and they did their job a couple times already. I saw a couple of dings from some careless persons car door on the moldings.
I ended up mounting them about a 1/2” above the door panel body line.
I don’t know if that’s the exact installation placement but they worked good so far.
I’ll attach a picture, hopefully this helps.
Hello,
Please share the link for moldings
Hello,
This is the part number I ordered for my Wind Chill Pearl body side molding: Part Number: PT29A-60240-31
I ordered mine from Stevinson Toyota West (autoparts.stevinsontoyotawest.com) for $242 shipped:
Note that you need to order the right part number (suffix) for the color of your car. Also note that the colors oftentimes go by different names -- the "Platinum White" body molding color corresponds to the Wind Chill Pearl color on my car. You can see the selection of colors for the Land Cruiser here: Land Cruiser Body Side Moldings
Thanks a lot! I think I need PT29A-60240-37 for my car
it documentation color of the car recorded as - avant garde bronze metallic
Yea, as I said Toyota uses different names for the same color, which makes things confusing! This same color is also called Brown Sugar Metallic in other uses!
You can be sure of the color match by looking at the 4-digit color code (which for Wind Chill Pearl is "0089", and for Meteor Shower is "04V8"). This color code should remain consistent regardless of the color name (e.g. Avant Garde Bronze Metallic, Brown Sugar Metallic and Meteor Shower should all have the same color code, 04V8). The color codes are included in the attachment I provided earlier.
I should note that I am assuming that the colors you have in Azerbaijan are the same as we have in the US, but I don't know that for sure...
I think they work pretty good. That's my FJ door swinging into the new molding. (WCP)
I agree, I think they look and work great. And, there's a nice side benefit -- they almost completely eliminated the "tinny" vibration sound that the doors had when they closed. Now (if the window is up) the door closes with a nice "thump"!
(Unlike the GX, Toyota didn't put any sound insulation in the LC door panels.)
Paid under $200 on ebay for colour coded side-moldings. Although I actually chose black for my white LC. Basically just eyeballed fitting to line up with crease in doors.
Interesting. I was just wondering about the contrast of using OEM black moldings on my WCP. Thx for the pic.
Hello,
Thanks ^^^ did you notice if road noise was reduced ??
I have always really liked mine but that black may have been the way to go with my black roof and pillars
Like what you did. Like to get some in black...
Toyota ordering site needs some help !
