so if wanted higher lift you recommend to extend the sway bar?SDM won’t affect a lift either way.
If you lift over a certain amount you’d want extended sway bar links for either SDM or the standard bar.
I would get the SDM if you can.
Got it. Thank you. So while on subject what are your thoughts on the stock suspension and springs on the Land Cruiser? I currently have 4runner and running bp51 kit. Different beast but curious on your thoughts. I have rtt, rack, drawer system, fridge and some other weight. Thinking of moving to LC so trying to learn all I can. Appreciate the insight.If doing more than 2" you will probably want a panhard (extension) bracket. Depends on your goal. Unless you are replacing a lot of components, you are usually giving up suspension travel (and articulation) proportional to lift... for my uses the articulation is more valuable than raw clearance. I could see a use case for extreme breakover or increasing water fording depth with lift, but depends on what you want to do. If I wanted to increase approach/departure angles I'd probably change the bumpers before going above 2" lift.
Thanks. Just trying to figure it out. Prob drive it a bit as is with minor adjustments to learn its capabilities than make any mods from there. But I will want my off-road tires and wheels, add rack, rtt, awning, lights and any under protection. I’ll need strong enough springs suspension etc to hold all this as well.Just going by memory, I think over two inches you’d want to get extended sway bar links. I know at least King and Dobinson have them available for their taller kits.
I’m not aware of a 4” lift. That would be a major undertaking including all kinds of new parts, not just the standard shocks and springs.
What are your plans for the truck?
I started my last post before you and dubel posted then came back without refreshing, so I missed this before.Got it. Thank you. So while on subject what are your thoughts on the stock suspension and springs on the Land Cruiser? I currently have 4runner and running bp51 kit. Different beast but curious on your thoughts. I have rtt, rack, drawer system, fridge and some other weight. Thinking of moving to LC so trying to learn all I can. Appreciate the insight.
74Weld has portal axles for almost 4” of lift and Dissent Motors has run with 38” tires, you might want to check out their builds.so if wanted higher lift you recommend to extend the sway bar?
You think 4 inch lift would be fine with extended sway bar?
