That is pretty slick. Thanks.I use this—super simple and works great. Custom Metal Mounting Bracket for Adhesive Dashcam Lenses
The issue I have is where to mount a cam. Most cams are mounted to the window and with the back hatch on the LC finding a clean method of attaching is a problem I haven't solved.Looks like what you want is the Garmin Dashcam Tandem.
Do you have a picture of yours installed?I use this—super simple and works great. Custom Metal Mounting Bracket for Adhesive Dashcam Lenses
Holy crap! I'm buying this right now, sooo much better than the neodium magnets I'm using. Thank you for the link!I use this—super simple and works great. Custom Metal Mounting Bracket for Adhesive Dashcam Lenses
here you go! Collage from the rear and front, respectivelyDo you have a picture of yours installed?
