Looking to save a little on LC250 products?!
Luigi
56
147
San Jose, CA
2024 LC250
Now is the time. Save a little money using my coupon code: “2yotas1fam” on all LC250 products with CA Tuned Offroad. High quality products that not only look great, but are functionally as well. Rocksliders, brush bar/bull bar, on board arb kit, ditch light brackets, or a rear cargo upper shelf that doesn’t require rear molle panels to install.
More products to come! Stay tuned. Land Cruiser
Your truck really looks awesome! I am looking closely at the Dobinsons MRR set up as well but would not go as large as you did on the tire because I am on-road mostly and want the mpgs. Can you tell me what lift you did to get 37's on there and fit so well? Did you lift above 2" or 2.5"?
thanks!!
thanks!!
Hi. Thank! Went with the MRR Extended travel kit. The preload is set to about a 2.5ish lift give or take. Not that bad putting on 37’s. Some minor trimming and removing the body mount plates and front air dam plastic trim piece. Super easy.
