I stand corrected, amazing result considering the damage!
Now we know is okay to back into things to judge distance.
You might try "Chemical Guys" VRP, I really like it.I was running errands yesterday, mentally going through the best method for my DIY repair. I thought why not just check with a paint-less dent option. To my surprise I was 1 mile from the closest location. Pulled in and the owner says let’s give it a shot. 30 minutes later the result is almost perfect, minus the scuff marks which I can live with. He charged me $60 which was the best $60 I have spent this month….lol. The solution was removing numerous inner plastic panels, a blow dryer and hand pressing the dent out. Did not have to remove the cover.
Again thank you all for the quick responses and great ideas, problem solved!
Same with my Outback....used a golf driver after the hair dryer to push it out.Hair dryer and you can reshape a lot back to semi-normal. Did something similar to my GX and it worked. Would try the manual manipulation if you can access.
That is easy 1. Warm up the corner plastic bumper 2. Push from inside!I could be wrong, but from what I can tell that entire bumper cover is < $400. My advice would be to try to get it where you can live with it knowing the replacement isn’t so expensive that you don’t have a backup plan.
I would let the pros to fix it. I had a similar problem with a BMW. The metal was hammer out and the plastic heated to original form. Try "Bumper doctor"Well eventually it happens and it sucks when it does. Parked for a quick run into the supermarket. Returned to the LC to find a heavily dented corner on rear bumper. It separated the fender flair, fortunately that snapped back into place. Seems the plastic clips were not broken fortunately. I have looked under the bumper to find its not as simple as pushing the crushed corner back out. You can see the plastic has a white crease line at the top so I already know there will be a blemish regardless on how well I can restore it. I am questioning has anyone removed the inner liners and accessed the back side of the bumper? Also wondering if a hammer “plus what” should I use to pound the dent back out? View attachment 67019
I did this! Bought all the essential tools for a PDR so I could fix a small dent on my wife’s care. Very happy with the result, but not as good as when I’ve paid for PDR, and I definitely spent more on the tools than I did on paying someone to do it for me.
Welcome to the asylum.Same with my Outback....used a golf driver after the hair dryer to push it out.
