Going with Eibach Pro Stage 2R
Looks great! I am waiting for my call that Dobinsons parts are in - any day now.
Curious that you have some rubbing at wheel well at full lock with 35" x 11.5". Is your offset +35 on those methods?
looks good!
I’m sitting on the fence right now on what to do-I’ve got the Pro BBS’s (+47.5) and have zero rub with the 285/70 Toyo AT3’s, but I kinda want to go a bit bigger. Thought about 295/70’s, but I’m a tad worried about UCA rub since they list as a bit wider.
Decisions decisions
It is +35
It’s about mid fender well bottom 1”. Thinking about using a heat gun and just remolding a little. Shop said they would move the fender well liner for me. If I wanted. By modifying the holes to new mounting positions.
I have a little rake left and not sure if I want that or not.
What’s the consensus on rake. Yay or nay?
looks good!
Decisions decisions
I also have the Pro BBS at +47.5 and will be going to Toyo 285/75/18 (34.8") within a week. Slightly concerned about the same -UCA rub but I think I will be OK at approx 11.3" wide.
Ok. So got the LC back and it looks great. Have a tiny bit of rub on driver front fender well full lock right in reverse. Will take care of with a heat gun. Here are some before and afters. Ride is more firm than stock but not rough. Feels very good.
Looks great! What height did you set the fronts at?
Right now they are in the 38’s. Going to let it settle in then adjust. The rears are right around 40 so I was thinking 39 at each front.
I’m interested in how it works out. Are you lifted at all?
Doing a 2" lift front and rear with Dobinsons, adding the BBS TRD Pro, and Toyo ATIII 285/75/18. Cannot wait to finally get this done and hoping all works smooth.
Exactly what I have currently minus tire size. Send pics!
So stoked for this. Date set this afternoon for installation - Thursday the 11th. Driving 4 hours for this installer because their reputation is good and they have been really excellent at discussing details.
Will definitely send pics.
Did you actually adjust the coilover from its factory setting? If so, do you happen to know or remember how much you adjusted it? I ordered this kit and will be installing soon, so just looking for a reference point. Thanks!
