Front spoiler removal?
Repsol69
28
10
Florida
ram truck/Jeep
Has anyone removed those little pieces in front of the front tires under the bumper?? the little triangular ones ...THX
Yes. I had them removed at dealership. But it would literally take 2 minutes to do yourself.
Yeah, super easy you take those air dams off and then there are two other plastic pieces you can remove to give it a cleaner look. Takes like 5-10 mins.
Yes I took those off too. 4 pieces total. Definitely a cleaner look. Thx
Yep - there are a few twist fasteners and one rear pin in the smaller part nearest the inter-wheelwell. The rubber front pieces directly in front of the tires have 3 (I think) screws in the bottom and two pins in the back. As stated above, they are quick and easy to remove.
Exactly didn’t take long
Question - what about the little white plugs / inserts that the screws go into, you guys leave them as is?
Nope, leaving mine alone until the mileage and under vehicle turbulence doesn't matter.
Right now it does.
