I took the new ride to the summit of Pikes Peak today. Engine pulls great at high altitude, but coming down was a bit of a different story. Would love some advice and feedback on this.
I find the engine braking, gearing down to M2 and M1, lacking in the ability to effectively slow the truck on steep grades. Admittedly, it's a long steep decline there but I've done it many times and can usually baby brakes to keep them cool. Today the LC brakes got to 320 degrees at Glen Cove checkpoint. Could smell them slightly coming down, and knew I was on them more than I wanted even before getting a temp read. Never got fade, but concerning.
I find gearing down tends to get the motor quickly spinning at 4 or 5k rpms, but the speed is still picking up. There's just not a lot of engine braking to be had.
I experimented going into 4 low, and that was better, but the engine still wants to rev very high, and the speed still gets away from you, though more slowly, and on flatter sections you're stuck with being in low range.
Either gear range, the high RPMs are a bit disconcerting.
Am I missing something here? A setting, a mode selection, a technique, something..? I live in Colorado and have noticed a lack of slowing at highway speeds gearing down, but not to the point of brake temp concerns. I'm an experienced mountain driver and have not had a history of being hard on brakes. But I'm sure wide open to suggestions
I'm only 2k miles in and haven't done real trails yet, so a bit concerned on steep downhills. Maybe this is better at crawling speeds?
Of all the mods, I'm thinking beefed up slotted rotors and the best pads money can buy might be on the shortlist.
Any thoughts much appreciated.
