CO BDR
Norwalk, CT
2025 Toyota Landcuiser 1958
Got back about a week ago from doing the CO BDR. Roughly 5000 miles for the whole trip. Land Cruiser handled it like a champ.
Only 2 complaints I have are small fuel tank and the trans did overheat going up Corkscrew and had to pull off to let it cool down.
so cool. Any chance you could share your gpx file? 🙏
Yeah, I dont mind. Its the official BDR route, but has spots we camped out or found on the route that we thought were good for coming back too. Each section was a day.
View attachment 77423View attachment 77424View attachment 77425View attachment 77426View attachment 77427
Congrats on a great adventure. Ref the "trans overheating". A little lesson I learned in Moab on Fins & Things...steep climbs require high engine RPM & low speed, which turns the impeller in the torque converter [which is in the xsmn casing] at the same engine RPM. This xsmn fluid, which drives the transfer case to the axles, instantly converts this high RPM to thermal energy/heat...overheating the xsmn fluid. Solution is use 4L, lets the physical gears carry the load. Instead of 2300 RPM and crawling along up a steep incline, you work at a much lower RPM and gain a mechanical advantage. CAVEAT---my comments are rudimentary; there are some really qualified people on this forum who I hope will correct my mistakes. It is obvious I'm no expert, nor do I claim to be. I believe no one lives long enough to make all the mistakes, so we should learn from others.
Thats the weird thing, I was in 4L most of the day that we did ophir, and part of the alpine loop. It crept up to overheating, car warned me and I stopped and let it cool. It didnt come up the rest of the day either though. Always stabilized about 3/4 of the way, on the temp bar. ( wish I was able to see the temp)
there are people who put in place a new cooler system with the adaptation to solve problems on oil transmission temperature
If you're up for the hassle, a good OBDII scanner and OBD app will let you see the temp. I have been using a Carista Evo and Car Scanner (respectively). Reviewing some screen captures, I see two items highlighted below-
