BLACK FRIDAY DEAL OF A LIFETIME $199 and won’t last long - I bought two as back up Milkwakee compressors with batteries and chargers
I guess that I have been living under a rock. I haven’t seen this before. Can this compressor take, say, all four 33” tires from about 15 or 20 psi to 32-ish psi on a single charge? If it can, can it do so twice? (A total of eight 33” tires on a charge?).
I have a small portable compressor now that I connect to the vehicle 12v battery. It’s slow but it does the job to allow airing up after the run down the trail. I’m wondering if/how this Milwaukee might be better/worse?
Stating to feel like a Milwaukee rep. Just a user of their tools.
@DM-CO - Yes it’s crazy robust. Got pretty cool here & Thu after turkey & did some tires pressure adjustment too about 15m on 2 vehicles:
  • Tundra/ dropped (4) 35x12.5R20 Nittos down to 26# then to 38#
  • topped off the spare from 33 to 50#
  • LC w/ 33” AT4W dropped the tires to 25#, then up to 38#
  • topped spare to 50#
All on 5Ah battery without charging
@SimplyAnAdventure - The non-Milwaukee jumper is just that, a jumper for 12v system. The Milwaukee $300 starter is the common battery & supercapacitor unit. If battery is low it helps give it a bit more. I carry one on the ranch & this spare one for my Tundra. It would be perfect to turn on the LC electronics & let DC hybrid battery start the rig.
Thanks for that. I’m impressed. This might make a nice replacement to my current compressor as I could use the Milwaukee battery and same my 12v LC battery.
I think they should give you a battery or two for the.... plug!
I wonder how that actually works? Milwaukee makes a jump box to run on M18’s but it’s about 5X The size of this one and about $300. I like the idea of this a lot I’d just hate to actually need it and find out it’s not enough. Any experience using it?
I started looking and then found this. It looks to be more of a charger than booster. It looks like after connecting it will charge the battery to give it a jump which is also kinda cool, but I like the booster style.
Then I also found what it appears like the eBay link seller is making there’s from but without the breaker. This one seems a little sketchy without a breaker, just for safety sake but it sure is inexpensive.
Great prices. I probably need the circuit breaker as I’m using on other equipment where it can get tight around the battery (the LC for sure & 25Hp Skag zero-turn comes to mind) & don’t want to fat finger a power connection. For sure the M18 Jumper is just a nice to have.
Our LC I’m using the BS200 I mounted in the battery compartment to jump start (& monitor the pathetic Yuaso battery). Put a BS300 on my sisters LX600 yesterday that has a larger H7 battery & it’s ‘real’ starting battery on the V35A.
I have used mine dozens and dozens of times, six to seven trips to Moab. Has no issue with 33's. Multiple fills on a 5ah battery. Just used it at work this weekend going from 25-65 psi on a 12k lb vehicle out in the sand, have done that many times as well.
@DM-CO I'd guess it will do four tires 15-20 times from 13-38 PSI based on my experience. I've yet to have to recharge even one of the two batteries after two years of having it and with a 1200W inverter it's hardly a concern.
It is quite quick and the bonus is you don't have to carry permanent weight around and it's mobile for use on anyone's vehicle in the group without repositioning.
Been thinking of picking up an air compressor capable lift bag for emergency trail jacking such as those made by The Bush Company which does engine exhaust or compressor. These things can lift in really soft conditions and can reach around 31" of lifting and support the entire vehicle weight.
