Two more options:Here are brackets with no drilling required, as well as some forum posts where they are discussed:
Rago Fabrication A-Pillar Light Mounts
CAtuned Off-Road Ditch Light Brackets (personally don’t recommend anything from this manufacturer due to customer service and quality issues)
- Manufacturer page: 2024-2025 Toyota Land Cruiser A-Pillar Light Mounts
- Uses OEM hood hinge bolts; fully bolt-on with no drilling or cutting. Adjustable forward or outward for ditch or cornering angles.
- Forum member install: Rago Fabrication Ditch light brackets
KC HiLiTES A-Pillar / Ditch Light Mounting Brackets (2024–25 Land Cruiser 250)
- Manufacturer page: CAtuned Off-Road 2024+ Toyota Land Cruiser Ditch Light Brackets
- Direct bolt-on using factory mounting points; no modifications required. Limited vertical adjustability depending on light pod.
- Forum member install: Finally, ditch light brackets!!!
- Manufacturer page: A-Pillar / Ditch Mount - 24-25 Toyota Land Cruiser
- Bolt-on using OEM hardware, no drilling. Adjustable light pod slot for side or forward aim.
Good luck!
NYTOP:
- design looks very strong. Not a fan of the silver hardware or the logo. But the placement of the lights looks very good:
- NYTOP | 2024-Current Toyota Land Cruiser Ditch Light Mount
SDHQ:
- had a pair of A-pillar brackets from them on my Raptor and they were excellent.
- requires some cutting or purchasing an additional laser-cut cowl.
- SDHQ Built '24-25 LC250 A-Pillar Light Mounts
