3 Numbers Below Vin
MAC25LC
65
105
Sumter Sc
25 Land Cruiser
Anyone know the significance of the 3 numbers below the VIN.
It’s a factory production sequence number used internally by Toyota during assembly. Each vehicle that rolls off the line gets a number like this, and it usually indicates the order in which it was built at that specific plant. So if yours says 272, it likely means it was the 272nd vehicle of that particular model (or drivetrain variant) produced in that run. It doesn’t show trim level or anything about where the car was shipped, but it does give a rough idea of how early your vehicle was in the production batch. Toyota owners sometimes track these out of curiosity, especially for new model years or limited production runs.
Anyone know the significance of the 3 numbers below the VIN.View attachment 40766
Google says........
The 3 digits located under the Toyota VIN (Vehicle Identification Number) are part of the vehicle's serial number, specifically the last three digits of the 17-digit VIN. This sequence of numbers and letters is unique to each vehicle and is used for internal identification purposes by Toyota. The first three digits of the VIN, also known as the World Manufacturer Identifier (WMI), indicate the country of origin, manufacturer, and vehicle type.
Huh...mine is "250"...I assumed it just referred to "Land Cruiser J250"
If that is the sequence number it’s just for internal tracking and that’s it. It has nothing to do with model or anything like that. You have to see if it matches the body # which should be on the radiator support under the hood.
