TSB 2027 Land Cruiser Pre-Delivery Service (PDS) — T-SB-0026-26
A Toyota Technical Service Bulletin: repair guidance for dealers on a known condition.
Imported from NHTSA data · last checked Nov 19, 2026
LandCruiserForum
Administrator
Staff member
⭐ Supporting Member
Technical Service Bulletin · T-SB-0026-26
This is a Technical Service Bulletin, not a recall. A TSB tells dealers how to diagnose and repair a specific symptom when a vehicle comes in with it. It doesn't mean every vehicle listed has the problem, and it doesn't by itself make the repair free -- coverage depends on your warranty and the dealer's diagnosis.
Published: Apr 10, 2026
Applies to: Land Cruiser (2027 model year)
Summary (official text)​
Pre-Delivery Service (PDS) is a critical step in satisfying our new car customers. Customer feedback indicates the following areas deserve special attention when performing PDS: •Careful inspection for paint chips/scratches and body dents/dings. •Proper operation of electrical accessories. •Interior cleanliness. •Proper function of mechanical systems. The PDS process helps identify potential vehicle concerns before customer delivery. After completing the PDS process, maintain accurate PDS records by ensuring the required documents listed below are completed and recorded in accordance with Toyota Warranty Policy. •GTS+ Health Check •Completed PDS Check Sheet •Battery Charge Test Print Out •GTS+ Tire Pressure Information Customer retention and proper maintenance of vehicles are and have always been a major focus for Toyota. To help remind customers that regular service is essential to the proper maintenance of the vehicle, dealers are required to install a service reminder sticker prior to delivery. By doing this, customers will be reminded to return to your dealership for service. Your current service reminder sticker may be used. This bulletin contains the PDS procedures that apply specifically to 2027 model year Land Cruiser vehicles.
Sources​
  • T-SB-0026-26 (PDF, NHTSA document 11032470) — Apr 10, 2026
Details from NHTSA as of Nov 20, 2026. If NHTSA or Toyota revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
Have you experienced this issue with your vehicle? Let us know your model year and engine, plus any diagnosis or repair details.
