- Sep 24, 2026
- 72
- 25
Technical Service Bulletin · T-SB-0104-23
This is a Technical Service Bulletin, not a recall. A TSB tells dealers how to diagnose and repair a specific symptom when a vehicle comes in with it. It doesn't mean every vehicle listed has the problem, and it doesn't by itself make the repair free -- coverage depends on your warranty and the dealer's diagnosis.
Published: Jun 14, 2024
Applies to: Land Cruiser (2025 model year)
Also listed in the source (outside this forum's coverage): 4RUNNER 2025, 4RUNNER I-Force MAX Hybrid 2025, BZ4X 2025, Camry Hybrid 2025, Corolla 2025, Corolla Cross 2025, Corolla Cross Hybrid 2025, Corolla Hatchback 2025, Corolla Hybrid 2025, Crown 2025, Crown Signia 2025, GR Corolla 2025 and 20 more
Details from NHTSA as of Nov 20, 2026. If NHTSA or Toyota revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
Have you experienced this issue with your vehicle? Let us know your model year and engine, plus any diagnosis or repair details.
Summary (official text)
TSB: During the manufacturing process, tires are mounted on the vehicle as matched sets to help reduce conditions such as pulling or drifting. If the wheels are replaced or refinished before vehicle delivery, it is important that the tires remain on the vehicle in the same location and in the same direction of rotation. Refer to the Tire Positioning Procedure in this bulletin to ensure that the original tires stay in the same location on the vehicle.
Sources
- T-SB-0104-23 Rev1 (PDF, NHTSA document 11005053) — Jun 14, 2024
- T-SB-0104-23 Rev1 (PDF, NHTSA document 11005111) — Jun 14, 2024
- T-SB-0104-23 Rev2 (PDF, NHTSA document 11012746) — Dec 6, 2024
- T-SB-0104-23 (NHTSA document 10248827; the PDF is not available from NHTSA yet) — Dec 21, 2024
