- Sep 24, 2026
- 72
- 25
Technical Service Bulletin · T-SB-0021-24
This is a Technical Service Bulletin, not a recall. A TSB tells dealers how to diagnose and repair a specific symptom when a vehicle comes in with it. It doesn't mean every vehicle listed has the problem, and it doesn't by itself make the repair free -- coverage depends on your warranty and the dealer's diagnosis.
Published: Apr 5, 2024
Applies to: Land Cruiser (2025 model year)
Restrictions stated in the source:
Also listed in the source (outside this forum's coverage): 4RUNNER 2025, 4RUNNER I-Force MAX Hybrid 2025, BZ4X 2025, Camry Hybrid 2025, Corolla 2025, Corolla Cross 2025, Corolla Cross Hybrid 2025, Corolla Hatchback 2025, Corolla Hybrid 2025, Crown 2025, Crown Signia 2025, GR Corolla 2025 and 21 more
Details from NHTSA as of Nov 20, 2026. If NHTSA or Toyota revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
Have you experienced this issue with your vehicle? Let us know your model year and engine, plus any diagnosis or repair details.
- Equipment: equipped with two types of batteries / equipped with only a 12V battery
Summary (official text)
A battery in a stored vehicle is subject to conditions that can reduce its performance and service life. These conditions include storage period, temperature, parasitic drain, and battery load. Because of these factors, battery inspection and maintenance are required in order to ensure proper operation and optimal battery life. Electrified vehicles are equipped with two types of batteries, a High Voltage (HV) battery and a 12V battery. Conventional vehicles are equipped with only a 12V battery. As a matter of policy, Toyota does not provide battery warranty coverage for discharged and/or failed batteries due to lack of maintenance. It is the dealer’s responsibility to maintain the specified State-Of-Charge (SOC) of the vehicle’s battery while in stock and ensure proper SOC at delivery. To reduce customer service concerns due to an undercharged battery, ALL dealers should test the 12V battery and recharge, if necessary, no more than 48 hours before delivery to the customer.
Sources
- T-SB-0021-24 (PDF, NHTSA document 11003559) — Apr 5, 2024
- T-SB-0021-24 (PDF, NHTSA document 11003614) — Apr 5, 2024
- T-SB-0021-24 Rev1 (PDF, NHTSA document 11005055) — Jun 14, 2024
- T-SB-0021-24 Rev1 (PDF, NHTSA document 11005113) — Jun 14, 2024
- T-SB-0021-24 Rev2 (PDF, NHTSA document 11011651) — Nov 22, 2024
