2024+ Toyota Land Cruiser - Single 30" PRO Light Bar
Fitment
Install
Light output
The PRO light bar uses a Combo Pattern, blending spot and driving optics for a balance between distance and width.
Every PRO bar is dual function, one off-road main beam that runs alongside an amber DRL (daytime running light) backglow.
White: Super bright, crisp white beam with plenty of light for any adventure.
Yellow: Cuts through dust, fog, snow, and rain far better than white light. Ideal for poor conditions.
Amber DRL, Both colors come with the same amber daytime running light backglow. Doesn't give off much light, just a bold amber glow that makes your vehicle stand out on the road.
Build quality
Questions about fitment on your rig? Ask here and we'll help.
Fitment
- Fits 2024–2026 Toyota Land Cruiser
- Trims: Land Cruiser 1958 and Land Cruiser
Install
- Installs behind the lower grille
- Doesn't interfere with radiator airflow
- Doesn't interfere with active grille shutters
- Metal bracket has a rail system that allows you to move the light bar up/down to your liking
- Metal bracket is powder coated black
- No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware
Light output
Build quality
- Higher light efficiency: brighter, longer irradiation distance
- Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to protect against UV, salt water, corrosion, fading and scratch resistant
- Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
- Rated for a 50,000 hour lifespan
