- Sep 24, 2026
- 72
- 25
Technical Service Bulletin · T-SB-0021-25
This is a Technical Service Bulletin, not a recall. A TSB tells dealers how to diagnose and repair a specific symptom when a vehicle comes in with it. It doesn't mean every vehicle listed has the problem, and it doesn't by itself make the repair free -- coverage depends on your warranty and the dealer's diagnosis.
Published: Feb 10, 2025
Applies to: Land Cruiser (2024–2027 model years)
Also listed in the source (outside this forum's coverage): 4RUNNER 2025–2027, 4RUNNER I-Force MAX Hybrid 2025–2027, BZ 2026–2027, BZ Woodland 2026–2027, BZ4X 2023–2025, C-HR 2026–2027, Camry Hybrid 2025–2027, Corolla 2023–2027, Corolla Cross 2022–2027, Corolla Cross Hybrid 2023–2027, Corolla Hatchback 2023–2027, Corolla Hybrid 2023–2027 and 24 more
Details from NHTSA as of Nov 20, 2026. If NHTSA or Toyota revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
Have you experienced this issue with your vehicle? Let us know your model year and engine, plus any diagnosis or repair details.
Summary (official text)
Flash reprogramming allows the Electronic Control Unit (ECU) software to be updated without replacing the ECU. Flash calibration updates for specific vehicle models/ECUs are released as field-fix procedures described in individual Service Bulletins. This bulletin details the Global Techstream+ (GTS+) ECU flash reprogramming procedures and outlines use of the Technical Information System (TIS) and the Calibration Update Wizard+ (CUW+). To ensure the correct ECU software is installed, ECUs will require a Security Signature before the ECU will initialize the flash reprogramming sequence. This bulletin also details the process for acquiring a Security Signature from TIS during the GTS+ ECU flash reprogramming process.
Sources
- T-SB-0021-25 (PDF, NHTSA document 11015496) — Feb 10, 2025
- T-SB-0021-25 (PDF, NHTSA document 11016782) — Feb 10, 2025
- T-SB-0021-25 Rev1 (PDF, NHTSA document 11039881) — Oct 30, 2026
