TSB 2024–2025 Land Cruiser Electrical System — T-SB-0011-25
A Toyota Technical Service Bulletin: repair guidance for dealers on a known condition.
Imported from NHTSA data · last checked Nov 19, 2026
LandCruiserForum
Administrator
Staff member
⭐ Supporting Member
Technical Service Bulletin · T-SB-0011-25
This is a Technical Service Bulletin, not a recall. A TSB tells dealers how to diagnose and repair a specific symptom when a vehicle comes in with it. It doesn't mean every vehicle listed has the problem, and it doesn't by itself make the repair free -- coverage depends on your warranty and the dealer's diagnosis.
Published: Jan 23, 2025
Applies to: Land Cruiser (2024–2025 model years)
Also listed in the source (outside this forum's coverage): 4RUNNER 2025, 4RUNNER I-Force MAX Hybrid 2025, BZ4X 2023–2025, Camry Hybrid 2025, Corolla 2023–2025, Corolla Cross 2022–2025, Corolla Cross Hybrid 2023–2025, Corolla Hybrid 2023–2025, Crown 2023–2025, Crown Signia 2025, GR Corolla 2023–2025, Grand Highlander 2024–2025 and 18 more
Summary (official text)​
When certain vehicle ECUs are replaced, the ECU Security Key must be written in order for that ECU to communicate on the vehicle network. The GTS+ Software Health Check Results screen has been enhanced to help identify if a replacement ECU requires an ECU Security Key.
Sources​
  • T-SB-0011-25 (PDF, NHTSA document 11014190) — Jan 23, 2025
Details from NHTSA as of Nov 20, 2026. If NHTSA or Toyota revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
Have you experienced this issue with your vehicle? Let us know your model year and engine, plus any diagnosis or repair details.
