- Sep 24, 2026
- 72
- 25
Technical Service Bulletin · T-SB-0039-24
This is a Technical Service Bulletin, not a recall. A TSB tells dealers how to diagnose and repair a specific symptom when a vehicle comes in with it. It doesn't mean every vehicle listed has the problem, and it doesn't by itself make the repair free -- coverage depends on your warranty and the dealer's diagnosis.
Published: Jul 12, 2024
Applies to: Land Cruiser (2024–2025 model years)
Also listed in the source (outside this forum's coverage): 4RUNNER 2000–2025, 4RUNNER I-Force MAX Hybrid 2025, 86 2016–2021, Avalon 2000–2022, Avalon Hybrid 2013–2022, BZ4X 2023–2025, C-HR 2017–2022, Camry 2000–2024, Camry Hybrid 2006–2025, Camry Solara 2000–2010, Celica 2000–2006, Corolla 2000–2025 and 46 more
Details from NHTSA as of Nov 20, 2026. If NHTSA or Toyota revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
Have you experienced this issue with your vehicle? Let us know your model year and engine, plus any diagnosis or repair details.
Summary (official text)
The condition known as acid rain is caused by airborne chemicals or particles in the atmosphere, which mix with rainwater, nighttime dew, or high humidity to form acidic compounds. If these contaminants settle and remain on a painted vehicle surface, especially the horizonal areas of the hood, roof, and decklid, significant damage can occur. This damage is the result of actual etching of the paint and appears as pitting or water spots. As acid rain droplets on the vehicle surface evaporate, the concentration strength of the acid increases, causing deeper and more rapid damage. This evaporation and corrosive action also occur more rapidly on dark colored cars as direct sun heat increases. It is the dealer’s responsibility to protect and maintain the quality of the vehicle’s paint finish after receipt at the dealership prior to the first sale. In areas known for high frequency and/or concentration of acid rain, frequent vehicle washing during high heat or humidity periods will minimize the potential for paint damage caused by acid rain. It is further recommended that either reverse osmosis or deionized water be used to prevent water spotting.
Sources
- T-SB-0039-24 Rev1 (PDF, NHTSA document 11006151) — Jul 12, 2024
- T-SB-0039-24 Rev1 (PDF, NHTSA document 11007445) — Jul 12, 2024
- T-SB-0039-24 Rev2 (PDF, NHTSA document 11012744) — Dec 6, 2024
