TSB 2024–2025 Land Cruiser Acid Rain — T-SB-0035-24
A Toyota Technical Service Bulletin: repair guidance for dealers on a known condition.
Imported from NHTSA data · last checked Nov 19, 2026
LandCruiserForum
Administrator
Staff member
⭐ Supporting Member
Technical Service Bulletin · T-SB-0035-24
This is a Technical Service Bulletin, not a recall. A TSB tells dealers how to diagnose and repair a specific symptom when a vehicle comes in with it. It doesn't mean every vehicle listed has the problem, and it doesn't by itself make the repair free -- coverage depends on your warranty and the dealer's diagnosis.
Published: Jul 12, 2024
Applies to: Land Cruiser (2024–2025 model years)
Also listed in the source (outside this forum's coverage): 4RUNNER 2000–2025, 4RUNNER I-Force MAX Hybrid 2025, 86 2016–2021, Avalon 2000–2022, Avalon Hybrid 2013–2022, BZ4X 2023–2025, C-HR 2017–2022, Camry 2000–2024, Camry Hybrid 2006–2025, Camry Solara 2000–2010, Celica 2000–2006, Corolla 2000–2025 and 45 more
Summary (official text)​
Acid rain results from rainwater or other airborne moisture that become acidic due to industrial chemical impurities in the atmosphere. If these acidic compounds settle on an exposed vehicle, especially the horizontal areas such as the hood, roof, and decklid, significant damage to the painted surfaces can occur. Acid rain damage can typically be identified on vehicles by the presence of stains on the paint surface that resemble hard water spots. Unlike water spots however, acid rain damage cannot be removed by regular washing procedures. Also, because acid rain can etch and soften the paint, normal buffing or polishing repair procedures should not be attempted. This can cause further damage and result in visible depressions in the paint surface. The following are the three major categories of acid rain damage: •Minor damage: requires only buffing to repair. •Moderate damage: usually requires neutralizing, color sanding, and buffing. •Severe damage: extending beyond 1/2 mil of clearcoat on a pearl, metallic, or solid color, requires neutralization, sanding, and repainting. In cases where acid rain damage is minor, neutralization and buffing with a liquid-type paint finessing product may provide an adequate repair. Only specially formulated products outlined in this bulletin should be used for that purpose. Unfortunately, other than minor damage, there is no simple method of determining the actual extent (depth) of acid penetration other than color sanding a representative affected area until there is no visible etching or depressions, followed by measuring the amount of paint removed with either a magnetic or digital-type film thickness gauge. The procedures in this bulletin are intended for use by qualified body/paint technicians and should not be attempted by inexperienced personnel. It is the dealer’s responsibility to protect and maintain the quality of the vehicle’s paint finish after receipt at the dealership prior to the first sale. Perform frequent vehicle washing, as often as daily, during high heat and humidity periods to minimize the potential for paint damage due to acid rain exposure. This is especially important in geographical areas known for high frequency and concentration of acid rain and industrial fallout.
Sources​
Details from NHTSA as of Nov 20, 2026. If NHTSA or Toyota revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
Have you experienced this issue with your vehicle? Let us know your model year and engine, plus any diagnosis or repair details.
