Unknown Noise While Driving, Ideas?
gradles
Boston MA
Land Cruiser 1958
Update 5/18 - toyota took the vehicle for two weeks and turned it over and ended up claiming the following resolved the issue; a rubber gasket on the upward shaft protecting the transfer case had lost its lubrication where the gasket met the transfer case. Its rubbing/friction was causing the noise. They reapplied lubricant and could not duplicate the issue afterwards. I think theres still some of the noise but its 95% improved.
Photos of the report from the dealership included
For the last half year or more my trucks been making noises while on the highway. It's erratic, with no apparent pattern, and very high pitched. It almost sounds like metal scraping on itself. It's as unpleasant as bad feedback on a mic.
It's prominent in the cabin. And outside it must be horrible. Now that spring is here I've opened the windows and it gets to be very loud outside the vehicle. I've attached a video that catches the noise. I was worried that it was so high pitched a phone might not pick it up.
It started off happening pretty seldom, then over time it happens a lot more. Lately (last few months) it happens over 25% of the time I drive. The last week its happened more times than it hasn't. It lasts for generally the whole trip, which for me is typically 30 minutes - 90 minutes.
All that said, I have no idea what's producing the noise. The dealership doesn't either. Neither does Toyota. (both the dealership and Toyota have listened to a clip of it.)
Anyone have a clue what this noise is?
  • IMG_8749.mov
    14.7 MB
I have this exact same noise on and off for the last 6 to 12 months and I have no idea what it is either. There seems to be no rhyme or reason when it occurs for me. It doesn't happen every time I drive and I would say it doesn't happen about 70% of the time.
Id recommend calling ahead & schedule visit to your dealer. Have service advisor, better yet a technician, ride with you.
Best guess 20K’ guess - Maybe a brake pad dragging?
Does it go away if shifted to neutral? Does it go away when coming to a stop? What about when stopped in Park after it has started?
These can narrow it down between drivetrain and engine so it's easier to isolate.
Carry a good jack with you, after it starts pull into a parking lot and jack the corners up individually and rotate the tires by hand to see if you can reproduce.
