Iβm going through a Toyota dealership. Theyβve been super helpful and gave me a good deal if I bought my tires through them. He said they will swap them out for me and make sure working. Weβll see. Now Iβm just waiting on Toytec. Iβm ready to lose the soccer mom look of my LC with 20β wheels and get some A/T tires on it!Hopefully you have better luck than I did, Discount Tire couldn't do it with their tools. The guy tried 3 different things.
Any tips on how you got it to work?Hell yeah, I'd say the ride quality has improved as well. Also just as an update I did get my TMPS sensors to lock in this afternoon, so I'm happy now.
Thanks @JordanJ. Iβll be patient and hope they get picked up sooner rather than later. I guess I need to find an excuse to go for a long driveI donβt know if itβs any help, but I swapped my falkens straight off my Tacoma with after market tpms sensors, all I did was try to add them using the settings accessed through the steering wheelβ¦ took probably a week, long enough that I had given up on it completely and then suddenly they synced and had no issues since. So my advice would be just be very patient. I donβt know what the magic was, maybe itβs a distance thing? Like 25 miles was what it needed? And being nowhere near any other sensors? No clue.
If itβs any help at all, my routine at the time was start the βsyncβ at my local Sheetz, and drive roughly 50miles to workβ¦ they suddenly registered roughly halfway to workβ¦ but I had been trying about 4-5 days, but again, absolutely no clue was the special sauce was. My only thought is that most attempts were starting from my house, so that was in range of the Tacoma, so maybe that was what was glitching it out originally? And again, best guess I have is that there was like a required mileage that had to be obtained? And I did take it to a local tire place and they said they couldnβt get it. Maybe itβs just my sensors? No idea man, but good luck!Thanks @JordanJ. Iβll be patient and hope they get picked up sooner rather than later. I guess I need to find an excuse to go for a long drive![]()
This certainly could be, and I just happened upon the circumstances naturally, good to know!Its not very clear in the manual but you need to select register new tire set in the menus (you'll see where it tell you to drive but don't), you'll need to have the hybrid system on without driving for about 15 minutes, then it needs to turned off for about 30 minutes and then driven afterwards and then parked for a brief period and it will complete the cycle. Took mine about 20 miles of driving both times I did it. The manual also mentions that slightly curvy roads are preferred.
Not an easy process for me with two overactive kidsIts not very clear in the manual but you need to select register new tire set in the menus (you'll see where it tell you to drive but don't), you'll need to have the hybrid system on without driving for about 15 minutes, then it needs to turned off for about 30 minutes and then driven afterwards and then parked for a brief period and it will complete the cycle. Took mine about 20 miles of driving both times I did it. The manual also mentions that slightly curvy roads are preferred.
