So what's the general consensus about running aux power to the main fuse box? I've seen mix things about this, its either that or run a kit from the back to the front.
All I'm wanting to do is wire in my Garmin power switch to power the following:
- 7 Diode Dynamic SS5s: 2.8 amps each, 3.07 watts each
-2 Diode Dynamics SS3 ditch lights: 1.1 amps each, 14.5 watts each
I don't plan on running a winch for awhile, I know you'll need to run it from the battery. Think I'll be ok with the garmin at the main fuse box?
TIA!
TIA!
