The 2026 RAV4 rollout had some news about CAN BUS hardening so I asked the all knowing AI to summarize the changes. Not sure it is all correct but it seems like a step in the right direction. Could skip the "built-in drive recorder" but most of that is already there not being able to spoof the doors and starting would be good.
The same AI said TSS 4 on the LC for 2027, but no reference. Anyone have visibility to the TSS 4 rollout schedule?
Toyota models with Safety Sense 3 (TSS 3.0) and earlier remain high-risk targets for CAN bus injection attacks that bypass the smart key system. Thieves gain physical access to the CAN bus wiring by peeling back fender liners or prying exterior panels or breaking glass to reach the connectors or other exposed wiring looms. A malicious device is plugged into this wiring to inject commands. Although these vehicles use TSK/SecOC (Toyota Security Key/Secure Onboard Communication) to protect some communications, as of early 2026, the "start" and "unlock" authentication for the platform has not yet been fully hardened against all localized injection methods, and thieves are using sophisticated tools to replay known valid messages. Once connected, a handheld device injects malicious code that mimics a "Key Validated" signal. This tricks the Engine Control Unit (ECU) into unlocking the doors, disabling the immobilizer, and allowing the engine to start. Then thieves use these same devices to disable the factory Toyota Connected Services GPS tracking, making the vehicle difficult to recover.
Toyota models with Safety Sense 4 (TSS 4.0) are considered more secure against high-tech theft—specifically CAN bus injection—primarily because it is integrated with the new Arene software-defined architecture. While TSS is primarily an active safety suite for accident prevention, its introduction on the Arene platform includes fundamental shifts in vehicle security. TSS 4.0 utilizes hardened SecOC (Secure Onboard Communication) protocols. Every critical CAN message now includes an 8-bit checksum and unique cryptographic key verification. Receiving ECUs (Electronic Control Units) ignore any message that lacks a valid signature, directly neutralizing "CAN Invader" devices that try to spoof "key valid" signals. The Arene platform allows for Over-the-Air (OTA) security updates. If a new theft vulnerability is discovered in the wild, Toyota can theoretically patch the vehicle's defense systems without requiring a dealership visit. A new feature of TSS 4.0 is a built-in drive recorder. While not a preventative tool, it can provide critical documentation of attempted thefts or tamperings. Models debuting with TSS 4.0 (such as the 2026 RAV4) use next-generation ECU silicon that has proven resistant to "glitching" or hardware exploits used by researchers to dump keys on older 2020–2021 models.
