Thanks, I did all that. It is actually a gate opener, but i don’t think that matters. I will open the gate control box and look for the learn buttonThis largely depends on the model of your garage door opener. If your vehicle has the digital mirror, it will display steps on the mirror to guide you through the steps, after you've cleared the previous programming. The owner manual has pretty good instructions, too. For some openers with rolling codes, you may have to get up on a ladder and press the "Learn" button one time.
That’s encouraging!We have a liftmaster driveway gate opener as well and I was able to get it programmed no problem. It’s a different process that a garage opener. You can use the remote to help program it. You have to open the liftmaster box and use the “learn” button and then follow the car programming instructions from there. I always forget how to do it exactly and then have to play around with it for 15 minutes or so when reprogramming a new vehicle or a new remote.
2:45 of this video forward.I having a problem getting the Homelink to work with my liftmaster gate opener Remote. Anyone have any tricks? It may be that the technology is too old to be compatible.
I could not get my lift master to work. Not with the learn buttons in the box and not with the generic clickers.
Only One thing did work. An OEM clicker. That is a lift master branded clicker.
I got the lift master brand clicker from Amazon. Trained the clicker with the learn button as the clicker comes with explicit instructions . And then trained the LC Homelink with the clicker in seconds.
I got my old 4runner to work with the learn button on the lift master box but not the LC.
most of the advice here is the same bullshit I heard taking me down a 6 week rabbit hole. None of it worked except this:
This maybe the answer I am looking for, thanks!I could not get my lift master to work. Not with the learn buttons in the box and not with the generic clickers.
