Multi Information Display Issue
TK3421
Virginia Beach
2024 Landcruiser
Today my multi information display stopped showing the tach and speedometer. The HUD is no longer visible either. I cannot select any of the preset screens as the “Home” and arrow buttons don’t seem to do anything. Anyone else experience this? Drives and handles normally with all sensors seemingly unaffected.
You might try disconnecting the neg battery cable to reset the computers........... seems to have solved a lot of glitches for me.
Had that during immobiliser install - switch off and leave for 10 mins - it resets apparently - or at least it did for me with the vehicle electrician there
I guess it depends what caused your issues - I was incorrectly disarming the immobiliser - let it “sleep” - did it correctly - all good
The screen I had was the one you are showing
The Land Cruiser and Lexus are having all kinds of electronic issues. It;s been going on for months without a fix.
How did you go with this mate? Mine has had the same issue just now. Did it correct itself?
just wanted to say that I had the same problem today and disconnecting the negative battery terminal worked to reset things back to normal, however seems like there should be another way to solve this problem
I have a solar battery charger mounted under the roof rack and that is keeping the battery above the min voltage Mine hasn't done it since...........
