🧡 Wanted LC/LC Premium/FE original flare fenders
Gt4
Canada
2024 Toyota Land Cruiser 1958
If someone plan to buy aftermarket extended flare fenders, I would be interested to buy your original LC/LC Premium/FE trim flares to fit on my 1958.
Let me know if you want to sell and ship your original plastic fender flares to Montreal, Quebec, Canada
I can also trade my 1958 for your wider if for some obscur reason you are willing to do!!!
Any bites? I'm curious about the difficulty Level on this swap and look forward to seeing the results. Also interested in doing the painted bumper panels and surprised we haven't seen a full or even partial 1958>LCLC exterior conversion yet.
I painted my front bumper caps and lower “skid” panel to look more like the higher trim on my 1958.
Very easy. A couple bolts and push clips and then pull straight out, it is held in by a bunch of clips. I’ve replaced the driver front wheel arch molding on my 1958 after damaging it. The difference is in the mud guards. The 1958 mudguards will not work with the fender flares. If you want to swap out the fender moldings for OEM flares they can be bought online for about $800, which is a lot for pieces of plastic that add ½”. I’d go aftermarket before doing that. NYTOP has some, they are 2” of flare.
Very easy. A couple bolts and push clips and then pull straight out, it is held in by a bunch of clips. I’ve replaced the driver front wheel arch molding on my 1958 after damaging it. The difference is in the mud guards. The 1958 mudguards will not work with the fender flares. If you want to swap out the fender moldings for OEM flares they can be bought online for about $800, which is a lot for pieces of plastic that add ½”. I’d go aftermarket before doing that. NYTOP has some, I believe they add 1 ½” of flare to the 1958 or 1” to regular LC.
Thanks for the info. Noticed a few options including the NYTOP but I still prefer OEM. Good to know about the mud flaps though, I guess I'd have to replace those too. Do you know if they are different front and rear?
Not yet. Not in a rush, pretty sure some guys will want wider flares in the future. I also have the JDM mud flaps to got with those OEM flares.
I know the back are definitely different. They have an additional mounting point up at the top and go up about 3-4”higher. They are molded to match up with the fender flare/molding, so I assume they are molded differently between the two styles in the front, but can’t confirm. Going to the OEM JDM mudflaps would alleviate the issue, look and function better, and likely be similar cost to the rigid mudguards.
still looking for genuine Toyota LC base/premium/First Edition flares foe my 1958
Moulding Set, Outside, Left Hand
Part Number: 75062-60070
Moulding Set, Outside, Right Hand
Part Number: 75061-60380
Moulding Sub-Assembly, Front Fender, Left Hand
Part Number: 75602-60100
Moulding Sub-Assembly, Front Fender, Right Hand
Part Number: 75601-60100
Moulding Sub-Assembly, Quarter Outside, Left Hand
Part Number: 75606-60170
Moulding Sub-Assembly, Qtr Outside, Upper Right Hand
Part Number: 75605-60170
The mud guards for the 1958 fit on the FE/Premium/LCLC flares. So basic pictures of mine. The rear flare and mud guard just needs simple hole relocating on the top. They are NOT perfect but you have to look close at both the front the rear to notice. I pulled my fronts because I went with GX550 side steps which I got $100 for the pair and lights in the them. Got the flares for $500, easy 20 minute swap.
You can maybe zoom in the pictures. Pic #3 zoom in for the front. This is before I went with the GX550 side steps. If you want I can get you some close ups of the rear flaps and maybe hold up for some pictures the front.
Rhino Rack
