Landrcuiser Engine Locked Up
Chris OM
Ireland
2019 Landcruiser LWB Commercial
Hey I have a 2019 2.8D landcruiser commercial. A few weeks ago after about and hours drive i switched it off for about 45mins. Hit the button to start and no go. Checked the battery, plugged in computer, no fault codes. The head up display is slow to load. Trucked it to a garage, the starter is burned out so replaced it, still no go. Put a wrench on the crank and the engine is locked up. Took out the injectors to see if fluid had somehow got into the cylinder but no good. There was no vibration/smoke etc. so I have no reason to believe the engine has gone bad. The transmission was removed to replace the egr cooler about 18 months ago. it had seemed to be loosing power when under heavy acceleration, I though that may have been an issue with the turbo but I'm now thinking it could be a fault in the transmission that has now locked up the drive train i.e maybe a bolt or something in the torque converter, does anyone have any thoughts?
Welcome to the asylum Chris OM. I hope that you can get your LC’s problems satisfactorily sorted.
Hey I have a 2019 2.8D landcruiser commercial. A few weeks ago after about and hours drive i switched it off for about 45mins. Hit the button to start and no go. Checked the battery, plugged in computer, no fault codes. The head up display is slow to load. Trucked it to a garage, the starter is burned out so replaced it, still no go. Put a wrench on the crank and the engine is locked up. Took out the injectors to see if fluid had somehow got into the cylinder but no good. There was no vibration/smoke etc. so I have no reason to believe the engine has gone bad. The transmission was removed to replace the egr cooler about 18 months ago. It had seemed to be losing power under heavy acceleration. I initially thought it was a turbo issue, but considering Diesel Tuning and the previous modifications, I’m now thinking it could be a fault in the transmission that has locked up the drivetrain, maybe a bolt or something in the torque converter. Does anyone have any thoughts?
Something in the transmission, most likely the torque converter or flexplate, is preventing the engine from turning. Check for a loose or damaged bolt, misalignment, or obstruction inside the torque converter or flexplate before assuming the engine itself is seized.
Welcome to the asylum.
