Key Cases
Syed117
130
294
NY
Land Cruiser 250
A little on the large side, but thought I would give it a shot. Key fits inside and case is held together with tiny screws.
Random seller on Etsy who can customize the back with whatever you want.
Yes, the physical key is trapped in there.
Please post the link
Does your key have a light function - UK has 3 - lock unlock and rear tailgate
Just a thought to those who get this (or any case with metal plating). In my Merc, the case was enough to attenuate the signal that it would occasionally flash a "key not detected" while driving, which is more than annoying at freeway speeds as you dig it out of your pocket to be "seen" by the car. The fob battery also drained quicker as the key attempts to negotiate with the car with the attenuated signal.
https://www.etsy.com/listing/1657296367/toyota-customizable-key-fob-cover
I was afraid of something similar, but I think since the metal only covers the borders, it should be ok. I haven't any issues with it so far. The overall larger size is the main issue.
