Is this lifted?
Rod
11
11
Maryland
Toyota Landcruiser
My apologies for the stupid question, how do you know if it’s lifted?
If it's lifted, it's a spacer lift since that's the stock shock/spring.
We need to see 3-4" above the top of this picture to tell if there's a spacer.
Ok, thanks.
Here’s another photo
I saw a lifted one at dealer and it had the same spacer as is shown in your second photo. The 2 pieces of sheet metal sandwiched together.
Reactions: Rod
Yeah, there's a spacer in there. Here's what stock looks like.
The two pieces @MSINAL is talking about are the shock top mount. The spacer is between those and the frame bracket that the top of the shock mounts to and has the bolts with nuts going through them.
Here's what stock looks like:
Reactions: Rod
Thank you
Thank you for the quick reply
