HVAC issues
magnusoskarsson
2
0
Iceland
Land Cruiser 200 (Year 2016)
Dear all,
I have a 2016, Land Cruiser 200. It is pretty much stock. The HVAC system has some issues that I have not been able to figure out or find any solutions online.
  • The HVAC system does not start until about a minute after starting the car. And when it does turn on, it starts in some factory default mode, 22°C with a little airflow, i.e. not set the way it was beforer. However, the car must have been turned off for a long time, maybe an hour. If you turn it off and then come back very soon after, the HVAC system often starts up right away as if nothing had happened. So the car needs to sit for a while for this issue to appear. This makes me suspect there is some battery or capacitor in the HVAC system that maintains its memory, and that it needs about a minute of charging before the system can switch back on.
  • The HVAC does not cool, or cools poorly. It is erratic. Sometimes it cools, sometimes it doesn’t. It was refilled not so long ago, so maybe there is a leak.
  • The air vents on the passenger side at the front of the car blow very weakly, while on the driver’s side the airflow is at full strength.
Does anyone have any tips on how to fix this or at least figure out what is wrong?
Thank you very much in advance.
Best,
Magnus.
Dear all,
Best,
Magnus.
Welcome to the Jungle!
You may get better answers if you posted in the older LC forum.
