How can I move my hologram speedometer up and down?
Go in the settings and look for HUD. Alternatively do a you tube searchHow can I move my hologram speedometer up and down?
When You are in settings. Hold down the OK button and you'll get to the screen to move it around. Also mine cuts off a bit to the right as well. Changing it to a 'full' type display helps because it is slightly skinierNo matter what I do, mine always cuts off a bit on the right. Does anyone know if the screen can be manually adjusted (EOD GUY...this one's for you...lol) so that it will slightly move to the left?
I've played with all of the adjustments in settings. I still get a slight cut-off on the right edge unless I shift my body over in what feels like an awkward position in the seat. I would like to physically shift the display...like adjust in the dash by loosening screws, repositioning and the retightening. I curious if that is possible.When You are in settings. Hold down the OK button and you'll get to the screen to move it around. Also mine cuts off a bit to the right as well. Changing it to a 'full' type display helps because it is slightly skinier
