Headlight Adjustment
jbtaco2002
76
106
SAN DIEGO
2025 Land Cruiser, 2018 TRD Pro Tacoma, 2021 Highlander Hybrid, 2012 4Runner TE, 2008 Sequoia Supercharged
Hey everyone,
curious if your beam pattern is similar.
I have the Westcott preload collar lift and adjusted my lights down a bit to hopefully be less blinding to oncoming traffic.
These pics are from 5 ft away on perfectly level ground. First pic is regular, 2nd is high beams. To me looks like driver's side needs to come up a touch. The "V" notches end up being right near the middle at like 30-40 ft out when driving at night. I didn't do any left to right adjustments. Not sure I need to. Rectangular headlights BTW.
Thoughts?
Here's the proper procedure with two distances to check/adjust at. The low beam cutoff line (lowest portion of the line on left side facing wall) will be either ~1.5" below your measured headlight center (H) distance at 25 feet or ~4" lower at the 9.84' distance and concentration of the beam should be dead center both horizontally and vertically on the (H).
Whole procedure attached.
  • TIS - TOYOTA 2024-2025 Land Cruiser Repair Manual (RM43A0U)Head Light Aiming.pdf
