E-O-H brake full time?
dtxlcfe
153
179
Dallas
2024 land cruiser 250 FE
Anyone using the electric over hydraulic braking (under 5000 lb) instead of the standard electric braking full time? I have switched between the 2 a few times and haven’t noticed a huge down tick in battery charging when using eoh. In my opinion eoh is a much more solid brake pedal feeling preferred to standard electric.
I don’t understand. I thought eoh meant it would apply both electric and hydraulic all the time compared to priority going to electric only then hydraulic when needed. I am convinced that when you enable any kind of trailer braking it changes the LC braking style to avoid solely electric braking as well. Am I wrong?
just makes sense that it would disable electric only vehicle braking while this was turned on. but maybe its just a coincidence that I haven't noticed any of those stutters where it swaps between electric/hydraulic, when I have this setting on.
Just a thought, but this setting is for the trailer brakes and probably is not active unless there were something on the seven pin connector.
