Brake booster / actuator noise
katekebo
Tucson, AZ
2024 Toyota Land Cruiser 1958
Since a few days, my LC (2024 MY, 12k miles) has started to make noise when I apply brakes. It's very intermittent and has only happened a few times. Also only happens when brakes are applied gently at low speed. Symptoms:
  • Sounds like electric motor or small pump with a loose or broken bearing. Lasts only a second or two. It is NOT the normal booster sound like when opening the drivers door after parking the vehicle or pressing the brake pedal a few times. It's much, much louder (at first I thought it was the dreaded transmission pump noise).
  • Accompanied by vibration in the brake pedal and the left foot rest. Kind of like when ABS kicks is, but this happens with gentle braking at low speed (less than 10 mph) on smooth, dry pavement. Also, noise and vibration is much stronger than ABS operation.
  • Seems to happen only when the vehicle is cold, like first few brake applications after being parked overnight.
  • Completely random, does not seem to follow any pattern, and only happens once in a while.
To make things worse, we are 1000 miles away from home and have to drive back for New Year.
From the symptoms it seems like the brake booster pump failing, but because symptoms are intermittent it's hard to confirm the source.
Has anybody experienced something similar? If yes, what was the diagnosis and remedy?
I’m not sure I can help aside from acknowledging a similar-ish condition. This is my second winter with this car. I did not notice anything last winter. Starting in November, mine makes a temperature-based (louder the colder the ambient temp) motor whine / pump running noise. I can’t say there are other issues, just that noise and again, when it’s cold outside. It starts when I press the brake, and stops either when I let off the brake OR when the brake hold light comes on (active). I think it’s the pump motor integrated into the master cylinder - booster thing. It works, but just makes noise. I’m waiting to see what happens late spring…
Do you get it in R and N? I have something similar but it is less intermittent. I will try to get a recording of mine.
I’m not sure I can help aside from acknowledging a similar-ish condition. This is my second winter with this car. I did not notice anything last winter. Starting in November, mine makes a temperature-based (louder the colder the ambient temp) motor whine / pump running noise. I can’t say there are other issues, just that noise and again, when it’s cold outside. It starts when I press the brake, and stops either when I let off the brake OR when the brake hold light comes on (active). I think it’s the pump motor integrated into the master cylinder - booster thing. It works, but just makes noise. I’m waiting to see what happens late fall…
Thanks for answering. Yes, it's similar to what happens with my car, but occasionally (maybe one in ten times) the noise is VERY loud.
I was able to pinpoint the noise to the ABS actuator/pump by asking my wife to drive the truck forward and back with the hood open. I can feel the ABS actuator vibrating while the "humming" sounds is generated. At least in my case, it is not the booster pump as I had it kick on during this and it makes separate "wrrrr" sound that I am familiar with.
I tried recording a video from the outside, but since the engine was running, it is impossible to hear faint humming sound. I also recorded a video from the inside where the sound is audible. I will upload it once it uploads.
To hear it, you would need to max the volume on your device.
  • Sounds starts at the 3 second mark when I start moving
  • Please ignore the brake scratching sound from 5-7s marks
  • Sound ends at 9s mark as I come to a complete stop.
  • Booster pump kicks on at 10s mark.
  • I start moving again at 14s mark and sound is back
  • I come to a complete stop at 28s mark and the sound is gone again.
