Android Auto wireless poor connectivity.
JustinHEMI
TN
2024 LC250
7000 miles in and still loving it. However, over that time, wireless Android Auto connection seems to have gotten worse.
I'm about 50/50 whether it'll connect without a wire and when it does connect without a wire, it'll frequently drop and reconnect.
This behavior seems to be getting worse. Not sure if it's the truck or the phone (pixel 9).
I suppose I should ask a dealer to look at it but wanted to see if anyone else has similar issues and found a solution.
"Just use a wire" isn't a solution to a feature that almost every other brand has nailed by 2025.
...but have they? I've similar complaints about wireless Android Auto (AA) and Apple Carplay across multiple auto makers... I'm sure some implementations are better than others (and for what it's worth I think the current Toyota infotainment software is awful in general), but I don't know it's an issue isolated to Toyota or the Land Cruiser(?) I'm sure that the model of phone you have and version of Android is also another variable...but I have a Pixel 8 with the latest Android version, and I've found wireless AA to be unreliable as well.
For me, anyway, the "solution" has been just that...to only use wired AA. It took some hunting down to find the setting, but I did find a way to completely disable wireless AA on my phone. Since I have a 1958, I took advantage of the smaller screen size and put a phone mount on the bezel that works nicely, along with a nice looking coiled USB cord, and just plug my phone in for any trip where I want to use AA, and it works flawlessly...and if I don't plug it in, it doesn't attempt to connect and bug me.
Before that, I did find that after the vehicle was started, if wireless AA hadn't connected, I could manually connect my phone in the vehicle's device settings...but even then, as you mention, there was the issue with it sometimes randomly disconnecting, and I found that whole process annoying, so I decided to just ditch wireless altogether.
I highly doubt a dealer could or would be able to do anything about it, other than maybe "pretend" to check for software updates to appease you...so I admittedly haven't cared enough to even bring it up with them.
I'm in the same boat as you!
Have close to 4k miles on mine and my Pixel 9pro always struggles to pair with the cars Android Auto!!
Additionally, during longer trips with my phone paired, I'll see random drops in connection and then it does a mini reboot of sorts and gets connected again.
It's getting frustrating now, and am also thinking of taking it to the dealership. Both my phone's and my car's softwares are up-to-date, so not sure what the problem is.
Do let us know what the dealership says when you takes yours in.
As a long time Android user dating back to the Nexus One, Google's implementation of Bluetooth and later Android Auto on its own hardware has always been a bit problematic.
With that said, Toyota implemented Android Auto is not great as with my Samsung S24 Ultra which works flawlessly on my BMW and a number of other makes that I have driven as rentals, is flakey on my LC.
I'm thinking it's an interference thing because my Android Wireless will connect, but I've narrowed it down to two locations where the connect will time out, and then come back a little further down the road. I've looked around and not found anything in terms of cell towers or the like around so I can't comment as to what it actually is, but for it to happen at these two spots (along my normal commutes, there obviously will be other spots) leads me to believe an external factor is at play.
I think a lot of the issues come from the pixel phones. I was fine with my Samsung, but since I switched to pixel I've had issues.
I'm also having issues withe the pixel wifi calling in places the Samsung was fine. I'm regretting this phone 9pro
Yeah, add me to that list (as I described in my above)...I would have thought that Pixel phones, especially the 8 or 9, would be pretty good in terms of updated tech, but who knows?
I've just resigned to using wired AA...I was already used it on my previous vehicle, so not that big of a deal to me...it would have been nice if wireless AA worked as advertised though.
Same deal with my iPhone 15 Plus and my 1958. It worked perfectly up until about 2 months ago. Now it connects when I start the drive and about 5-15mins into the drive it just drops and is gone. I have to go into the car settings and can see that the phone is still there but not connected. Have to slide the toggle that says CarPlay and then hello! I'm back!
Yes, they have. Toyota LC is the first vehicle I have had in recent years with this issue, among BMWs, Mazdas, etc.
Using a wire for wireless AA isn't a solution we should have to live with.
I have similar problems with my Pixel 8a. It will connect automatically for a few trips, then things go south and it won't connect at all. I try to reconnect my phone on the LC media sys, and it WILL let me connect the phone for calls, but not for Android Auto (for the latter, I get a very helpful message that tells me that "it failed to connect due to an error"...) I restart the head unit (hold the power button in for a few sec), but that doesn't fix the problem.
Interestingly, if I reboot my phone, that generally clears up the problem (at least for a few trips). All of my phone settings are correct, so I don't know if this is an issue with my phone, or with the LC. I don't have any problems if i plug my phone in via cable.
In any case, I'm pretty disappointed with this, I was expecting better from Toyota...
I have a similar problem.....2025 Prado Adventure AA will only connect via data cable. A friend of mine with Aug 2024 Prado Allrounder is able to connect via bluetooth. And yes his headunit has one SMARTDEVICELINK app factory installed which is missing in my vehicle
It continues to degrade since posting this. I'm going to wait until it gets to a point where the dealer can't claim "couldn't re-create the issue" and force them to replace the head unit.
I've had a couple of phones now with the LC and for me, it's a localized issue. Meaning, it only happens at certain locations and the exact same location on my way to work that it disconnects, then reconnect once I'm past it. So not a phone issue, but I guess some sort of interference?
Mine is even disconnecting when wired. "Connection timed out error" a lot.
