275/70/18 SL All-Terrain Tire Options
n0m@d
๐Ÿ“› Founding Member
Earth
Let's kick out 517s thread about tires! :) ๐Ÿ™ˆ
As many of you on this forum I'm trying to land on a set of 275/70/18 SL tires. So, I've tried to consolidate all the available on the market options into a single table. Let me know if I'm missing any options and I'll update the table. I'll also appreciate any real life reviews (rain, snow, mpg, road noise, durability, etc.)
MakeModelWeight, lbWarrantyPrice, $
General TireGrabber A/TX4660,000300
ToyoOpen Country EV4450,000350
NittoTerra Grappler G34670,000285
PirelliSCORPIONโ„ข XTM AT4855,000322
YokohamaGeolandar A/T44365,000260
Why a separate thread for this particular tire size/load/type combination? It seems to provide a number of benefits over the stock tires:
  • a little bit better ground clearance
  • better off-road performance
  • better looks
  • mpg is not so far away from stock tires
  • smaller-ish ground clearance hit by a spare tire
  • can reuse stock 18" wheels (33" tire on 17" wheel would be a perfect combo, but we are trying to stay on a budget here ๐Ÿ˜…. . . not exactly a benefit, more of a feature parity)
without cons coming with bigger/higher load tires:
  • more stress on breaks/suspension/drivetrain/powertrain components
  • bigger mpg hit => even less cruising range
  • doesn't fit into spare location (or if one manages to squish a bigger tire in, then it'll be a noticable ground clearance hit)
  • bigger odometer/speedometer offset
I am in the same boat! I was leaning towards the Generals, but I may look at the Toyos since they are a wee-bit lighter.
275/70/18 SL NITTO TERRA GRAPPLER G3
300 miles so far so good. No changes to handling. Very very slight road noise change. Very good in wet and snow conditions.
Weight and wet/ snow traction was the primary concern when selecting this tire.
I have been at 22mpg combined for the last 200 miles.
I very nearly went with the G3 for exactly this reason. It seems like the ideal size. We have 3 times as many options now as when I first compiled the spreadsheet!
I thought 275/70/18 did fit the spare tire location ?
Ive went for Michelinโ€™s in that exact size, havent used them yet because im waiting on new alloys arriving
anyone tried the toyo OC3 EV in SL? may go with these instead of E rated.
275/70/18 should barely fit in the spare location with some squeezing and it will definitely hang a little bit lower than stock. This is the view of Toyo at3 275/60/20 which is .2โ€ smaller through the rear passenger tire well
If anyone is looking for a really great deal on Nitto Terra Grapplers G3 shoot me a DM I have 4 with 150 miles on them 275/70/18. In AZ.
***Edit I went to 17 inch Method rims.
Another interesting find would be Goodyear Wrangler Territory MT, these are C load rated (sorry for off-topic), but still somewhat light for this size (comparing to E-load options) at just 52lb (6-8lb more than SL options mentioned above). One of the huge pros is relatively low price (under $200 at Discount Tire ๐Ÿคฏ), but the show stopper for lots of people likely would be lack of The 3-Peak Mountain Snowflake (3PMSF) rating ๐Ÿ˜ญ . FWIW it is one of the Ford Bronco's stock tires ๐Ÿค”
GoodyearWrangler Territory MT52???200
Discount/Americaโ€™s tire says this size is an OEM special version? I think they use this on one of the 4Runner trims? But possibly an interesting (and cheap!) option for folks in Texas or with snow tires.
I had the first gen Nokian Outpost on a previous vehicle. Was a great AT that handled well in the snow up to about 30-35k with 50% tread left. To be fair I have yet to find an AT that handles snow well after about 50% wear in general.
Latest Discussions
