2025 LC Trip Odometer A&B questions
Paul2660
Little Rock AR
2025 landcrusier
I have a couple of questions on the trip odometers, A and B.
Currently my trip meter is resetting every time I start the truck, I have checked settings and cannot find one to stop this.
I have found the settings for A and B, but cannot figure out how to have B? show up.
When I start the truck I have a trip meter in the center of the Speedometer, which shows trip distance and time of trip. I can't tell if this is A or B or something else.
I prefer not to have the trip meter reseting each time I start.
Thanks
Paul C.
It's separate... you have the A/B trip counters that you can reset manually and will continue to count until you do so...then there's also a trip-specific meter, which as you've noted includes both the duration in HH:MM:SS and the miles/km of the trip, and is reset each time you start the vehicle.
I'm not in my LC at the moment, but I'm pretty sure you can cycle through all of these in the info screen on the gauge cluster (I also have a 1958, so mine is likely to be slightly different to operate the menus than yours)
Thanks, I did finally figure this out. The MIDI 12 inch is quite a learning experience. Glad that it appears to be pretty standardized across the line Toyota cars and trucks, but it would be nice to see a Land Cruiser specific one. Ton of options on that screen, and unless you are using it very day, easy to forget how to access it. (at least for me as I learn by repetition).
Paul
Can somebody please post how to access the A/B trip counters that you can reset manually? thanks.
