You forgot the Overtrail. Far from a mall crawler. Front and rear sway bar disconnect, and robust 18" tires. Sad that Toyota did not come out with such a vehicle, but they knew the 2025 4Runner was in the wings. All controlled by the marketing side.All the better to traverse the treacherous speedbumps at the outlet mall
No change. Did they do it with larger tires or a change in the suspension? Is the articulation still the same?The 2025 GX Overtrail will have 1 inch lift compared to the 2024 GX Overtrail. New ground clearance is listed as 9.84.
How about the new 2025 Land Cruisers
No. My 25 is the same as the 24.The 2025 GX Overtrail will have 1 inch lift compared to the 2024 GX Overtrail. New ground clearance is listed as 9.84.
I’m being facetiousYou forgot the Overtrail. Far from a mall crawler. Front and rear sway bar disconnect, and robust 18" tires. Sad that Toyota did not come out with such a vehicle, but they knew the 2025 4Runner was in the wings. All controlled by the marketing side.
Excused.I’m being facetious![]()
Amazingly, they took away triple-zone HVAC from the Overtrail. Even the base LC 1958 trim has this.I think the better thing for the Lexus is that all trims come with memory seats and power tilt steering wheel. It was absurd that they didn't at their price.
It's a change in the suspensionNo change. Did they do it with larger tires or a change in the suspension? Is the articulation still the same?
Surely not a puck lift! Larger coils, shocks??It's a change in the suspension
Oh yeah? So what is the actual hardware change? Asking for a friend...It's a change in the suspension
The press release is pretty vague. My guess is different shocks and springs. I can't imagine Toyota using a puck lift. The ~1" leveling lift on the 2014 FJ TTUE was different shocks and springs.Oh yeah? So what is the actual hardware change? Asking for a friend...
It is vague, as always. I was looking to hear back from @gvan1998, as he made it sound like he actually knew how the lift is being accomplished.The press release is pretty vague. My guess is different shocks and springs. I can't imagine Toyota using a puck lift. The ~1" leveling lift on the 2014 FJ TTUE was different shocks and springs.
