2024+ Toyota Land Cruiser 30in Light Bar - SLIM (Single or Dual)
MandRautomotive
🛒 Supporting Vendor
Burbank, CA
2024 Land Cruiser
Fits 2024 2025 Toyota Land Cruiser
  • Installs behind the lower grille
  • Must remove whole front grille for installation
  • DOES NOT affect cooling of the radiator
  • DOES NOT interfere with active shutters
  • Metal bracket has a rail system that allows you to move the light bars up/down to your liking
  • Metal bracket is powder coated black
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
Choose your light bars colors:​
1) White LED -- Each up to 11,760 lumens, bright and powerful. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and can’t be used on the regular road. They will blind the in-coming traffic and also violates road safety.
2) Amber LED -- Each up to 5,500 lumens, used in poor driving conditions such as dust, fog, snow and rain. It reflects through air particles much less than the white light. Therefore, making it ideal for poor driving conditions.
3) dual function: main White LED light with Amber DRL backglow -- the white LED light is same as described above, but the amber DRL “daytime running lights” acts purely for aesthetics. It doesn’t give out much light, but more of a beautiful amber backglow. Since it doesn’t give out much light, you can use this amber DRL feature on regular roads, it doesn't blind in-coming traffic.
Single Setup - 2024+ Land Cruiser Single 30in Light Bar - SLIM
Dual Setup - https://mandronline.com/products/2024-land-cruiser-dual-30s-light-bars-slim
when you say "remove the whole front grill" do you mean the entire front bumper, or the upper middle portion to access that lower area? I plan to install a 30" lightbar down there, but haven't because it seems very challenging to access that area. thanks
EDIT< guess i should watch the video! lol
Haha yes it’s the whole front end but it’s not very difficult. We make videos to give you confidence to tackle the job yourself
Nice! do you sell just the brackets?
Installed amber 30" M&R lightbar. Looks amazing on a black land cruiser. And puts out A LOT of light.
#toyota #landcruiser #toyotalandcruiser #landcruiserprado #toyotagram #toyotausa #toyotalandcruiser250 #2024landcruiser
Whats better than adding one Land Cruiser Lightbar?
Hey guys, you can use coupon code COLBY10 to get 10% off of your purchase! Let us know if you have any questions.
Have your 30” LC light bar kit on order. I’m trying to get my head wrapped around what the best level to mount the M&R thin light bar for cooling.
Please explain the statement that “does not affect the cooling of the radiator,” & how that was decided/measured? After watching the vids appears your brackets allow you to choose where a single led bar to be mounted in one of the 3 different grill rows in the lower grill opening. You even offer that someone can choose to mount two light bars - that I would think would block 2 of the 3 rows of the lower grill. Did Toyota test the grill cooling with these lights, or who? I’m in Texas & occasionally tow a 4500# Centurion wake boat, so cooling is a concern as you can tell.
