2024+ Toyota Land Cruiser 30in Light Bar - PRO (Single or Dual)
MandRautomotive
🛒 Supporting Vendor
Burbank, CA
2024 Land Cruiser
Hey Guys
Got a cool product wanted to let you know about for the 2024 2025 Toyota Land Cruiser
  • Installs behind the lower grille
  • Must remove whole front grille for installation
  • DOES NOT affect cooling of the radiator
  • DOES NOT interfere with active shutters
  • Metal bracket has a rail system that allows you to move the light bar up/down to your liking
  • Metal bracket is powder coated black
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
DUAL COLOR
1) Main White LED Light with Amber DRL (daytime running lights)
  • White LED -- Super bright and crisp white beam pattern. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and can’t be used on the regular road. They will blind the in-coming traffic and also violates road safety.
  • Amber DRL -- amber DRL “daytime running lights” acts purely for aesthetics. Since it doesn’t give out much light, you can use this amber DRL feature on regular roads, it doesn't blind in-coming traffic. Amber DRL is the perfect match to drive around town.
2) Main Yellow LED Light with Amber DRL
  • Yellow LED --excellent choice for improving visibility and safety, especially in challenging conditions. Yellow LED light cuts through fog, rain, and snow better than white light, making it ideal for bad weather. For off-roading, it’s a game-changer, helping you navigate dusty trails and uneven terrain with ease. This is still for off-road use only as it is bright and will blind the in-coming traffic and also violates road safety.
Single Setup 2024+ Land Cruiser Single 30in Light Bar - PRO
Dual Setup 2024+ Land Cruiser Dual 30s Light Bars - PRO
Looks really good. I can't imagine putting that front bumper back together though... Likely why the video glossed over that part.
Hey everyone, be sure to use coupon code COLBY10 at checkout to get 10% off of your purchase!
