2024 FE Edition: Swapping rock rails for OEM running boards from LC edition
oerdem19
Houston
Land Cruiser 2024 FE
Hi everyone,
Does anyone know if I can just swap my rock rails from 2024 FE edition with running boards from LC edition? I am not sure if they are going to fit exactly.
If it does not fit, any suggestion for running boards?
Thank you,
Yes you can, I just switched from OEM rock rails to OEM running boards a couple of days ago.
The only difference is the mounting points. The steps mount to the body (6 bolts), and the rock rails attach to the frame (8 bolts). The necessary hardware for the steps are already bolted onto the body, no need to purchase mounting bolts.
Thank you very much.
